Terrible gas milage
Terrible gas milage
I have my engine running really well but I have put about 20 miles on it with a full tank of gas and now its nearly empty. What could be causing this??
- chevyguyjay
edoggdoremus
- Goped
- Streetglow
- Goped
- Streetglow
- Goped
edoggdoremus
- Goped
my carb is leaking. very slowly when in idle but when i rev it it increases, and im sure it leaks even more when in full throttle. Seems a lot of leakage is around the base of the airfilter tube. Could this be a bad gasket? I took the carb apart last week and the float seemed to be working correctly
Dirty carb... likely a non-closing float valve. You should fix that.
I actually have a "Increase MPG" post under tech docs. Go read.
Admin, Hondaspree.net
PimpinSpree
