Pulley Mod
Pulley Mod
Ok, I read some of the posts which are supposed to make a Spree faster. The "pulley mod" refrences describe removing the lip on the inner pulley and replacing it with a washer.
What does this do ? Does it reduce the friction on the drive pulley and therefore allow it to spin more freely ? How does this improve the performance of the engine and does it destroy the power at the lower end of the rpm curve ?
I'm just trying to understand how and why this works since I can't find an explanation that doesn't simply say "It makes your Spree go faster".
Pulley Mod
Got it, so by shaving off part of the lip the position of the belt changes vertically within the "V" formed by the inner and outer pulley.
So by making the "V" narrower, you move the ratio between the front and rear pully closer together.
That would require you to spin the engine a little faster to get going, correct ? So the net result would be that the scooter feels like it has less torque but will end up with a higher top speed, correct ?
- Farfignugin
stillspeeding
Pulley Mod
I'm asking because my Spree is used as a pit bike for a racing team. What I really need is more low end torque rather than a higher top speed. So I'm looking for ways to get the scooter to accelerate quicker rather than something which accelerates more slowly but to a higher unltimate velocity.
So would this mod be good for my application ?
- chevyguyjay
Pulley Mod
Nah, too much money and work. I just want to make what I have run as best as I can until I can afford to get a Honda Ruckus.
PimpinSpree
You'd want to run a thin washer between the pulley halves instead to spread them. Also moves up clutch engagement a bit, which should help low end torque.
Pulley Mod
I just got the new clutch parts today so, I'll try the thin washer trick when I put everything back together. Thanks for the tips !!
- Farfignugin
