98 elite Go past 17?
ok i got a 98 elite and it starts awesome runs awesome all the way up until 15 mph then it bogs like a *, i cleaned the jet put new gas in it (was really old fromt he guy i bought it from) pipe is clean airbox and filter are clean.... what do u think it could be, maybe the fuel filter because of the old gas because it runs great until i crank on the throttle it just seems as the engine is getting starved.... what do you think....it has 400 miles on it flat
Dirty carb... go clean.
- KZ250andSpree
- BMX
Agreed. My spree was bogging really badly lately so I cracked open the carb, which I had been meaning to do for a while anyway. There was at least a quarter of an inch of crap in the bottom of the floatbowl from the gas that had been left in there for seven years ><
1980 KZ250LTD (need to get it running ><)
1986 Spree
1986 Spree
Not clean = bogging.
Plug cap loose from the wire... check that.
Vacuum leak from improper reassembly.
yes, that is what i was thinking a friend of mine who is a certified tech took it apart and reassembled it everything is clean and looks fine.
If you put your finger over half of the intake opening on the carb it runs great but the second you take it off it goes bad again.
jsut let me know all help is wanted thanks
- Farfignugin
- Farfignugin
