Need advice for a '96 Honda Elite 50
Hello,
I recently purchased a '96 Elite SR50 in need of a crankshaft and top end. After looking at VTCycles price list, it looks like its better to buy new than to repair what I have. Especially when replacing a lower rod bearing at my local motorcycle shop will cost me $65 in labor as that not something I have the tools to do myself.
I have rebuilt engines before, but know nothing about the manufacturers of top ends you have for sale. Based on price vs performance (or cc size), I was thinking about purchasing the F.M. 85cc Bore Kit & F.M. Stock Replacement Crank. Is there a better combo in the same price range?
Also, can these over bore kits be used with the stock carb (with rejetting) and exhaust?
The main goal for this project is to get it up to 50 mph so my wife can ride it to work. She'll have to navigate one main road with a speed limit of 50 mph.
Is that possible?
I emailed a similar message to VTcycle a few days ago but got no response. Are they a reputable dealer? Anyone in the continental US sell these parts?
THANKS!!
Is that possible?
THANKS!!
HuskieMobileMan
VT is very reputable. They only have 2 guys working there, so they are busy. Give them a call, or they will probably get back to you within the next few days. They have very good prices and tons of knowledge. They always throw in freebies too when you buy stuff from them.
'87 Elite SE50 w/65cc Polini Kit
'84 Aero NH125
'84 Aero NH80
'05 Kymco ZX50
'84 Aero NH125
'84 Aero NH80
'05 Kymco ZX50
that will not work on big bore kit on stock carb , not enough fuel !
just leave the intake on it, need adaptor ,then can runs 19mm dellorto carb w/ stock sr box. , fm stock crank. 72cc polini corsa bore w/ stock sr pipe
gear kit. less maintinace for everyday rides
ready to bolt on and hook everything up.
FM 85cc bore need to run big carb 28mm kehin pwk, big intake manifold gears, high speed pulley, gear kit, springs clutch and center. cannot run sr pipe, goona run pg long pipe.
need some case work on boost port
- hrnytrtlsgsxr
Thanks for the replies.
The 50 mph stretch is about 1.5 miles.
The only reason I was going to buy a new crankshaft assembly is because the lower rod bearing is shot. There's 2mm of play in it and it binds and sticks. The bearing is about $10 and it'll cost $65 to have it installed in the assembly at the local shop. That's $75 plus tax, more than a new crank. The speedo on this scoot is 1443 miles. But with this much wear on the engine, I think it may be 11,443.
Depends, if the bike sat alot, or the oil was of a poor quality, I seen engine with less then 1200 miles need new crank bearingsmrbones wrote:Thanks for the replies.
Myspree: You have the equipment to change out a rod lower bearing?
If your bottom-end is shot, might be a good time to upgrade to a stroker crank? Or might VT Cycles have a good used one to sell?
Ok, I finally got this bike put together with the 72cc kit, new crankshaft and new crankshaft bearings. Plus a #88 main jet in the carb. Thanks to vtcycles.com for the parts. I also repainted it flat red and the wheels gold. Looks cool. Had to get a new front brake cable and speedo cable, which was broke. That solves the mystery of the low mileage on the speedo.
The first time I ran it the top speed was only 37mph verified with a GPS. The belt blew up into little pieces on that run. That was fun, lol.
I then installed a new belt, a high speed pulley kit with 57g of weights, 8.44:1 rear gear set, high rpm clutch springs and a stiffer main spring on the rear pulley. Top speed is now 45mph. I weigh about 185lbs with riding gear so I think its doing pretty well.
I'm glad to say the brakes are still pretty good at that speed. The suspension is pushing it though. Not enough travel, but still manageable.
But, whats keeping me from 50mph? The stock exhaust, maybe? Is there any way to drill that sucker out?
Thanks!
Thanks!
