I've got a 1990 Dio AF27 with the following mods:
- high-speed pulley
- 6.5g roller weights
- Dio ZX belt (longer & wider than standard)
Also, the engine was rebuilt recently (new piston & rings). I do mostly highway riding, so I've set it up for top speed and can get 75kph (about 50mph?). So far so good.
However, around 45kph it hits "top gear" and the revs drop really low and it falls out of the power band. I craaaawwwl through to 50kph, the revs rise a bit, then it picks up again and I'm off.
Is this to do with the clutch centre spring, I mean the one that holds the rear pulley closed? Would a stronger spring keep the revs higher for longer? Or something else entirely?
I've already tried lighter roller weights, they just moved the flat spot a little higher (and took 10kph off my top speed)
I would love to get this sorted, as it's an awesome little scoot apart from that.
Thanks in advance!
