Wont run in the rain.....
- chevyguyjay
just like the topic says, i got stuck in the rain this morning. i couldnt get me scoot over 23mph. i have a 84 spree with a 87 elite se50 engine on it. any ideas would help.
- chevyguyjay
first we need to figur out if its an intake problem or a ignition problem. was the engine missing? because if it wasnt missing or reving weird or backfiring or anything it probably isnt the ignition. is that filter in a posistion where it could get wet? if the filter gets wet it will block a airflow and richen the mixture
stillspeeding
HuskieMobileMan
- chevyguyjay
that means its electrical. remove the coil and check the wire for any cracks it could be arcing somewhere. Check the wires coming from the pickup they could be shorting out. check the wiring in generalchevyguyjay wrote:well, the engine was like shutting off, then coming back on. it did this really fast, and could only get it to 23mph. im thinkin its in the electrical somewhere....
