I am putting back together my moped... I weight anywhere between 240-280lbs . i have a honda spree the nq50 1986. I am currently putting in a larger piston the .25 overboar..
As i am putting this back together i dont know what type of oil and what type of injector oil to use.... there are somany pages that recomented everything---
so. Big guy. 240-280 lbs. overboar and in wisconsin... what oils...
please help. This is going to be my summer trans. so its back and forth to class, work and the gym, and once and a wile to KFC. damm that chicken
I am no looking to race this think or get any tickets. just something that will make this last--
thanks -ahrenv
To many ideads on Oil????
- chevyguyjay
- Crotchrocket
- BMX
Honda GN2 Injector oil, ALWAYS....Also I coat the cyl wall,pin,pin bearing and rings upon assemby so she is never "dry" as I attempt the 1st start.
CR
CR
"CrotchRocket"
1994 Honda Elite SR-Polini 72CC Corsa kit-Polini Carbon Reeds-#100 Carb Jet-Keli Variator-1000RPM Center Clutch Spring-Ram Air Cooling-60MPH!
- 85spreeelite
Go Royal
Spend $15 and go get you some 2 cycle royal purple, I have been using that for years without fail in my scooters or my cars.
