Way too Fast!
hondaspree84
Way too Fast!
Post by hondaspree84 »
I just got the Spree running with a entire can of carb cleaner! (thanks Jerry).
Ok.. the only thing is that the back tire is racing out of control... I tried to adjust the speed screw-- but it just kept running fast...
Any Help Here?>
hondaman
way too fast
Post by hondaman »
Sounds like you are either adjusting the wrong screw or your throttle valve is either stuck or not in correctly.
vette76
Post by vette76 »
right, the throttle valve fits in the wrong way also and holds it at wide open.pull it out and turn it 180 degrees.(when u put it back in make sure it covers the hole,looking through the air intake side)
87' spree (SOLD
12' wrx
hondaspree84
Thanks guys -- I realize now that when you put the throttle valve in -- it shouldn't be hard to do... The line in the back of the valve was a good guide once i shine a flashlight on it...
Worked perfectly.!
