87 spree - many issues
BigK
Post by BigK »
I put a new battery in but the starter does not even make a sound. The spree hasn't been used in yrs, but in good condition. i banged on the server with a screw driver handle to loosen it, but it doesn't even make a sound. Any ideas
THe previous owner said the battery always gets drained all the time. So there is some short circuit somewhere.
I also cannot get the thing to start. The previous owner started it when I bought it, but it wouldn't stay started and the gas was leaking from it. They put the gasket on the wrong way.
My air screw is all the way closed because when open even a little, it leaks gas. I took the carb apart and cleaned the bowl and sprayed the float with carb cleaner. I took the springs out of the bowl and float and sprayed them and wiped them down.
I can't get it to start at all. I replaced the spark plug and it was working a little before I touched the spark plug. Then, I put the spark plug against the frame and I don't get any spark, so I am not sure how to test the wires and circuitry to make sure it works. Any ideas would be appreciated.
:oops:
BigK
87 spree
Post by BigK »
Correction: banged on the starter, not server!
vette76
Post by vette76 »
brake has to be inguaged when starting.
87' spree (SOLD
12' wrx
BigK
I feel stupid!
Post by BigK »
I am a dumb polack. Wholly crap!
It started, and the starter now works. Do you still need to hit the brake when you are kick starting?
Anyway, I got it started, but it sounds like it is flooding, so I will readjust the screws on the carb to where they should be and see if I can get it consistently working.
I can't believe i have been working on this time in and again and that is all it was. 8O
BigK
87 spree not waiting to stay running
Post by BigK »
I start it cold and it runs for about 1 minute on its own, then sounds like it gets flooded.
I cleaned the carb, so I am not sure what else it could be but a wrong adjustment on the carb.
Any other ideas or ideas on the carb? I checked the float. It is in good working order and not sticking. 8O
Clean the carb again, concentrating on the idle jet (small non-removable one next to main.)
vette76
Post by vette76 »
no, the brake doesnt have to be pulled in while kickstarting.
87' spree (SOLD
12' wrx
