ahrenv
Posts: 16 Joined: Sat Apr 21, 2007 4:50 pm
Post
by ahrenv » Fri Jul 13, 2007 10:04 pm
I am having troubles getting my moped to run and idle smoothly. When I go to give it gas, it seems to bog out. I think I have the problem narrowed down to timing, but I am up in the air and open to new ideas. Also if it is the timing,where and how do I go about adjusting that?
thanks-
ahrenv
Posts: 4957 Joined: Sun Apr 16, 2006 11:51 am
Post
by Kenny_McCormic » Fri Jul 13, 2007 10:22 pm
make sure your not running rich/lean do a plug chop
HuskieMobileMan
Posts: 167 Joined: Sun Feb 25, 2007 11:18 am
Post
by HuskieMobileMan » Fri Jul 13, 2007 10:48 pm
Timing is not adjustable. It is fixed inside the flywheel.
'87 Elite SE50 w/65cc Polini Kit
'84 Aero NH125
'84 Aero NH80
'05 Kymco ZX50
Posts: 4379 Joined: Sat Jul 31, 2004 8:00 pm
Post
by noiseguy » Fri Jul 13, 2007 11:20 pm
That sounds like lean surge. Check for vacuum leaks or an airbox problem.
Important to fix this now b.f you damage the engine.
