THe previous owner said the battery always gets drained all the time. So there is some short circuit somewhere.
I also cannot get the thing to start. The previous owner started it when I bought it, but it wouldn't stay started and the gas was leaking from it. They put the gasket on the wrong way.
My air screw is all the way closed because when open even a little, it leaks gas. I took the carb apart and cleaned the bowl and sprayed the float with carb cleaner. I took the springs out of the bowl and float and sprayed them and wiped them down.
I can't get it to start at all. I replaced the spark plug and it was working a little before I touched the spark plug. Then, I put the spark plug against the frame and I don't get any spark, so I am not sure how to test the wires and circuitry to make sure it works. Any ideas would be appreciated.
