1986 spree more speed
usdthrone23
Post by usdthrone23 »
ive got a stock 86 spree and it tops out around 30 ive read on another forum theres a screw in the transmission you can take out and gain up to 10 mph is this true or does anyone else have any suggestions ? other than cleaning out my exaust
vette76
Post by vette76 »
nothing u can do in the tranny. u can file the restriction out of the intake to giv an extra 4 mph.
87' spree (SOLD
12' wrx
usdthrone23
i dont know much about sprees/ engines in sprees :) can you step me through filing the restrictoer it would be greatly appreciated
vette76
Post by vette76 »
sure,on the carb, there are 2 bolts. remove them. what the carb is bolted to is the intake(aluminum side). after removing the carb there will be 2 more bolts on the intake,remove them.the intake should come off.look inside the intake on the side the carb was bolted on to and you will see a restriction.file it out with a small file or a dremel tool.(after its finished there should be a clear even path into the engine). clean out shavings and bolt back up again making sure all gaskets and vacume lines are where they were.
go here to see how it should look- http://www.freewebs.com/spreepics/performanceparts.htm
IGNORE the one with the brass fitting in it.you dont need to do this.
PS. when filing be careful not to file through the side of the intake.(this is why a file and not a dremel is recommended unless you are confident you can use a dremel skillfully.
87' spree (SOLD
12' wrx
usdthrone23
to many bolts to get off for me
vette76
Post by vette76 »
just 4.
87' spree (SOLD
12' wrx
usdthrone23
to take the casing off theres a few i cant get to so im stuck as of now but im looking for some extensions for the tools to help
BluPhire
Post by BluPhire »
So there are 5 bolts and 4 nuts and 2 of those weird plastic screw things (@ the back end of each side panel).
I try to fix things with a hammer and wrench!
vette76
Post by vette76 »
my panels arent even bolted down. they really dont need to be. they are a pain in the * to get off even without the bolts.maby its because i am using 1985 panels on a 1987 spree.
87' spree (SOLD
12' wrx
BluPhire
Post by BluPhire »
I just use zipties in place of those P.O.S plastic things.
vette76
Post by vette76 »
thats what i used for the front of the side panels to stop them from flying off at the super high speeds i can go.
87' spree (SOLD
12' wrx
BluPhire
Post by BluPhire »
lol. ya being pulled behind the 'Stang of urs
vette76
Post by vette76 »
lol. as soon as i get a batt for it. its getting to be a pain to roll it down the hill to start it.
87' spree (SOLD
12' wrx
usdthrone23
I got a new exaust pipe for it but it barely wont fit on, which was a waste and im stuck trying to get the second screw on the inside of the carb, i dont have a tool to reach it .... :cry:
BluPhire
Post by BluPhire »
What EXACTLY is the problem with the carb? What screw? Did you get the pipe for the right year? All screws (after the carb is off) can be tken off with any normal screw driver.
