leaking fuel...
leaking fuel...
took my spree out for a decent ride today, about 10 miles full throttle for a good amount of the trip. scoot goes about 25MPH. got home and smelled gas. checked and it was dripping rather rapidly out of a part behind what i believe to be the carb. on a whim, i decided to start the scoot again and turned it off. this resolved the prob... but i wonder, what the heck was that?!? is it a sign of problems to come?
Cold grinding grizzly bear jaws, hot on your heels...
Not enough information to tell you what might be wrong. Leaking gas is not a good thing on any engine or anything that gets hot. You will have to look closer to see where the gas is coming from. It could be a pinhole or crack in the gas line. I would try and find out where it is coming from unless you do not mind going out in flames.
Thank you, Hondaman.
Okay, did a little poking around and this is what I have come up with...
1) After riding, when I kill the engine, gas comes out of what I think is the overflow (rightside of carb, back, tiny pipe facing downward). Proabably enough gas to fill a shotglass or two.
2) I think this overflow(?) is supposed to have a tube attached to it but does not. But I did find a loose clear plastic tube, not attached to anything, when I took the panels off for a better look. maybe 3 inches long...
3) Also noticed on carb a tiny pipe coming out of the left side back, facing in (towards the middle of the bike). Looks like it should have a tube over it but does not.
Just to be specific: Gas comes out after I kill engine. Oddly, if I restart it and kill again, problem resolves itself.
Any clue?? And what of this little pipe on the left, back of carb? Should there be a tube going from it to somewhere else???
The outlet on the bottom of the carb should be your drain tube. There should be a flat head screw above it which is the drain screw. Turning the screw clockwise will shut it or close the drain opening. Counterclockwise will loosen it or open it up to drain carburetor of gas. Try turning it in to make sure it is closed all the way. A rubber hose is supposed to be attached here to make it easier to drain gas into a container.
That clear plastic tube sounds like your oil pump connection. It goes from the carb to the oil pump. If that is not connected no oil is being mixed with your gas. Unless someone has changed the lines that is the only clear plastic line I can think of. Are you premixing oil with gas before you dump it in the gas tank. That would be the only way I can think your engine would still be in one piece if your oil line has been disconnected. How long is this clear plastic tube that you are talking about?
It could also be like the other previous post said that your vacuume valve is not closing after the engine stops .This mean gas keeps flowing to your carburetor and is not being burned up causing the excess amount to flow out. If thats the case you can check it easily by unscrewing your drain screw and see if gas keeps coming out of the drain hose or drain opening. A little gas should come out and then stop. If it keeps coming out then your valve is stuck open.
sounds like a stuck float..
i would do the following first.. take off gas line to make sure the petcock isnt stuck open. A good test is to take off the vacuum line and give it a good suck, gas should flow freely and stop when there is no vacuum. If it passes all of those then take off and give your carb a good cleaning. Now i mean by cleaning, i mean to take it apart, shoot out al of the orifices with carb cleaner and some air would be nice too, check all the jets too. Make sure on your air fuel mixture screw , you know the exact amount that it is open. A easy way is to count the turns to close it, then remove it.
that would be where i would start ...
aloha
D
aloha
D
