dio stroker?
diomike
dio stroker?
Post by diomike »
i got a dio with
70cc athena
killi pully kit
8-1 gear ratio
tecnic gas pipe
crome manifold
28m carb
1500 cent spring
yellow cluch sprig
i was wondering wat kind of stroker i can get that will work with my config?? are they all warter cooled??? wat sizes are there?and do u got to get a case spliter to change ur crank shaft?
stillspeeding
Post by stillspeeding »
42-43- or 44.4 cranks are known as mini strokers, you can also do a japan rear pulley conversion but don't the michigan boys :lol: they are very slow these days :wink:
diomike
Post by diomike »
rear pully are u talking about useing the zx part??
stillspeeding
Yea, vt sells them for $65, mount it first with the belt and shave the 3 high spots with a dremmel or air tool grinder and you will gain an easy 5 mph :lol:
stillspeeding
So you boyz don't know about that conversion :lol: makes me know my engines! Ha! ha!
diomike
Post by diomike »
wat convertoin are u talking are u gonna tells us or keep it to urself
Dac
Post by Dac »
he talks 98% s***, dont try to understand him
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
diomike
Post by diomike »
ive only heard of thye zx convertion
stillspeeding
The zx rear pulley is only for the 94 and up sa-50 elites, it replaces the stock 2 pin pulley with a 3 pin and is 1mm taller thats why the inner trans high spots need to be shaved which takes about 10 mins, its a Taiwan pulley thats why its cheap! try it you may like it :lol:
Dac
Post by Dac »
how much does it help? or is it just one of those " i got a ----" type things, like after market reed valves.
veedubh20
Post by veedubh20 »
jog70cc can spank dio stroker motor anytime :shock:
diomike
Post by diomike »
i dont now about that
Dac
Post by Dac »
jogs are fast but dio's can Fly.
tru72
Post by tru72 »
actually Dac you are incorrect about jogs. LOL as much as i hate to admit it, the jog/minarelli motor set up is way more efficient working than a dio motor "chokes" cough , cough! hahah I have seen this play out many times. I know that a 72cc set up built on both motors ,perfectly tuned, jog wins. Dio motors are more preferred in the states... other places around the world are more jog. I hate the sound of that...
I prefer my dio stuff, but if i could find a good jog in good condition, i would defiantly build that too! Its all your personal preference!
just have fun!
aloha
D
ps listen to veedub, he knows his jogs!
diomike
Post by diomike »
i find that after owning a dio they tend to be unstable. my dio ran for a 3 weeks straight and now i cant get it to turn over. i cant figure the problem out
