Airbox cover and filter flew off, now bogs under throttle
d4founta
Post by d4founta »
The airbox cover and air filter flew off after hitting a hard bump in the road, now I can only go about 15 mph and if I give it any throttle the engine bogs down. Any ideas on how to fix this without getting another airbox cover and filter?
edjo
Post by edjo »
You need some sort of filter on the carb. Get a UNI, or make one out of a small paper filter, something. Then you are going to have to adjust the carb or maybe evn re-jet depending on your air filter solution. Good luck, Ed
88 elite SA50
07 DRZ436sm
05 FJR1300a
05 Dr200se
Post by Kenny_McCormic »
DONT RUN IT ANYMORE! IT WILL BURN UP LIKE THAT!
get a new filter before you even think of starting it again
d4founta
Post by d4founta »
What is a UNI? is this the easiest to get/ make?
Dac
Post by Dac »
UNI is a brand, they make air filters that will fit mopeds. UNI pod is a foam filter thats about 15$. although quick easy fix i wouldnt sugest it to you. running a UNI pod with out up-jetting can burn out your motor.
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
tru72
Post by tru72 »
to make it run the best, you would need to find a new airbox. Right now its running lean, that means easier to seize. Using any other after market air cleaner would be a pain because of the different air flow you get. It would be tuned like from the factory. Unless you have a after market set up.
aloha
D
hondaman
Post by hondaman »
You will just have to break down and get the original setup on there again. E-bay might be your best bet . Just wondering why you did not stop and retrieve the original one when it blew off?
