Reed valve
broomhilda
Reed valve
Post by broomhilda »
I've got carb off. If I want to check reeds what kind of wear am I looking for? If I take intake off, do I have to replace gasket? Looks plastic to me.
Thanks
edjo
Post by edjo »
I made new gaskets for mine when I pulled the reeds off out of gasket material. The reed block itself is plastic but there should be a paper type gasket on the top and bottom of it. You don't want them to have any open gaps around the sealing edge. Mine had a few small ones, so I flipped them over and that sealed them. If they are too out of shape you may need new ones.
88 elite SA50
07 DRZ436sm
05 FJR1300a
05 Dr200se
broomhilda
gaskets
what kind of gasket material. paper? Where can I get gasket material?
Sorry, but I am a noob.
edjo
Post by edjo »
I just got some at the auto parts store. I got fuel proof because I use it for other stuff, but I bet you can get away with the thinner stuff for this area. Anyways a place like Napa or any older parts store. Not sure if places like Checkers etc... will have. Just give them a ring.
88 elite SA50
07 DRZ436sm
05 FJR1300a
05 Dr200se
gsemack
Post by gsemack »
How did you make out with your reed valve? im trying to figure mine out.
broomhilda
reed valve
Well, I decided to look at the cylinder head instead- took off shroud/fan cover. How gross! Grease, dirt and grime!
Brake cleaning fluid seems to be my main tool these days.
