wiring help
dumdum9599
wiring help
Post by dumdum9599 »
hello all i need to know what to hock up to make my 84 spree fire. i should mention that it only has the puls coil wiers and the stator wirers left any help would be good.
andre
wikked_spree57
Post by wikked_spree57 »
You have to have a way to connect the CDI box and coil, not sure if you need anything else. The CDI and coil will produce your spark at the plug.
1994 BMW 525i 5 speed BEAMER TIME
1983 Yamaha XC 180 - Bought barn fresh in mint condition and 254 miles. Best bike I ever owned :)
dumdum9599
that is what i thought but which coil the puls coil or the spark plug coil.
andre
dumdum9599
but i thought there could be a way around using the cdi.
andre
dumdum9599
isn't there a way to hock up a different type of ignition. like say a coil from a car.
andre
Post by Kenny_McCormic »
it uses a very small ignition coil along with the cdi and pickup
dumdum9599
ok i found my cdi box and am now just trying to figure out the wirring. in the diagram i am reading i can't tell which wires go to each termanil on the cdi box.[/list][/code][/url]
andre
dumdum9599
ok i realy need help now. i have the ignition wired up to the bare esentials for it to fire but it does absolutly nothing. any ideas?
andre
