running spree in cold?
jayrey0910
Post by jayrey0910 »
spree ran 32-36 in warm waether now its cold and it goes 27-31. is it because of the weather?
Dac
Post by Dac »
possibly. my elite seems not to be hitting its top speed ether.
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
edjo
Post by edjo »
In the cold they will run leaner.
88 elite SA50
07 DRZ436sm
05 FJR1300a
05 Dr200se
Dac
Post by Dac »
thats what i thought. but its cool out and mine is smoking more. (so it seems)
smoke mean rich. and lean is mean, i would be going faster not slower. im confused
CharlotteSpreeRider
Post by CharlotteSpreeRider »
It also depends on the relative humidity of the climate. If the humidity is very low, what you see as "smoke" might actually be just steam, like when you can see your breath on "very" cold days. (I live in southern NC now, but I'm from FL, so this whole "cold" thing is still new to me. 80 degrees on New Years Day is not at all unheard of in Orlando.)
It's gotten quite a bit cooler in Charlotte in the past week, down to mid-40's in the morning when I'm leaving for work, and I've noticed my Spree produces alot more visible exhaust in the mornings than it did 2 weeks ago. Once it's good and warm though, it works pretty much just like when it was almost 100 degrees.
-aseigler
Post by Kenny_McCormic »
The cold air is denser to a point where you must richen the carb settings..
Dac
Post by Dac »
i can just set the carb. needle to the bottom-est setting ?
One notch down should be good.
Dac
Post by Dac »
ok thanks for the tip
Farfignugin
Post by Farfignugin »
You know it's cold out when you stick your head in the freezer to warm up after being outside.
Dac
Post by Dac »
i remember all that from last year, its cold out now, i dont want to even be here in a month
