Hard starting
nate_4027
Hard starting
Post by nate_4027 »
It ran fine this summer now you have to hold it wide open just to get it to start and sputter. Fuel is spewing out of the rear overflow tube. What's causing this I thought I had it fixed.
wikked_spree57
Post by wikked_spree57 »
Sounds like a sticky bystarter or float.
1994 BMW 525i 5 speed BEAMER TIME
1983 Yamaha XC 180 - Bought barn fresh in mint condition and 254 miles. Best bike I ever owned :)
Dac
Post by Dac »
float mabie.
by starter wouldn't cause that.
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
MichiganEd
Post by MichiganEd »
sounds like float to me..............not the bystarter
spinbreak
Hard Starting
Post by spinbreak »
Sounds like to me that it is the float sticking open or the needle valve is stuck open. Having to keep the throttle wide open says that you are flooding the engine when cranking it over. Needs more air to run then.
stillspeeding
Post by stillspeeding »
float valve is worn or needs adjustment, check the float pin for play.
Dac
Post by Dac »
stillspeeding wrote:float valve is worn or needs adjustment, check the float pin for play.
this is good advice.
nate_4027
Post by nate_4027 »
Wow thanks guys for all the help I'm glad you all agree on it being one thing.
