myhonda
Posts: 626 Joined: Sat Dec 31, 2005 7:00 pm
Post
by myhonda » Tue Oct 30, 2007 11:59 am
there is a lump in there i want to grind out. is there anything i should be worried about?
edjo
Posts: 113 Joined: Wed Aug 29, 2007 10:50 pm
Post
by edjo » Tue Oct 30, 2007 5:28 pm
Don't get bits in your eyes!!
88 elite SA50
07 DRZ436sm
05 FJR1300a
05 Dr200se
Posts: 4957 Joined: Sun Apr 16, 2006 11:51 am
Post
by Kenny_McCormic » Tue Oct 30, 2007 8:22 pm
In the pipe or in the jug? Go ahead and drill drill drill on that pipe.
stillspeeding
Posts: 279 Joined: Fri May 04, 2007 3:50 am
Post
by stillspeeding » Wed Oct 31, 2007 1:02 am
Only port the bottom of the exhaust port.
myhonda
Post
by myhonda » Wed Oct 31, 2007 6:49 pm
its on the jug. it isent honda ither. the hole in there is about the size of a quater but its blocked about half way by a lump of metal that needs to be grinded out.
myhonda
Post
by myhonda » Fri Nov 02, 2007 11:25 am
do i have to take the jug off to do this?
MySpree
Posts: 3291 Joined: Mon Jul 23, 1973 10:24 am
Post
by MySpree » Fri Nov 02, 2007 12:14 pm
i would, you dont want to get any scraps in the engien.
myhonda
Post
by myhonda » Fri Nov 02, 2007 2:13 pm
will i need new rings if i take the jug off? or gaskets?
Post
by Kenny_McCormic » Sat Nov 03, 2007 12:38 pm
Not if your careful. Unles it has a few thousand miles on it, then you should get new rings.
myhonda
Post
by myhonda » Sat Nov 03, 2007 1:13 pm
it has almost 2000 on it
Post
by Kenny_McCormic » Sat Nov 03, 2007 10:22 pm
Might as well while you are in there then. A few peopl have horror stories of reusing rings.
Dac
Posts: 3340 Joined: Sat May 05, 2007 5:58 pm
Post
by Dac » Tue Nov 06, 2007 3:21 pm
i reused some rings that came out of a fryed cylinder. they lasted 100 miles or so then busted and destroyed my new cylinder.
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
Post
by Kenny_McCormic » Tue Nov 06, 2007 5:19 pm
Perfect example^
stillspeeding
Post
by stillspeeding » Thu Nov 08, 2007 1:26 am
If its a spree don't even bother.
myhonda
Post
by myhonda » Fri Nov 09, 2007 8:08 am
no its a mz moskito but i figured that this would apply for any type of small engine
