What ring set?
ferchja
What ring set?
Post by ferchja »
There are two ring sets listed on the part fish, other than the oversizes. One is called "Rings, Piston" and the other is "Rings (STD)" I have both cause the local part counter screwed up the order. Which do you think is the stock set? I don't want to open them cause I don't think I can return it to them.
I assume those who have ordered rings can tell me the difference or enlighten me as to why there are two sets with what seem to be the same name.
Thanks in advance
Jeremy
85 Spree
vette76
Post by vette76 »
iwould guess "rings, piston would be it at long as it doesnt say oversized,or whatever.then again std can stand for stock diameter, so i wouldnt kno.
87' spree (SOLD
12' wrx
ferchja
Post by ferchja »
The part guy couldn't tell me either....it's a mystery.
Anyone order rings here recently? What is the part number you ordered? I will match to what I have and go with the concensus.
Thanks
Jeremy
vette76
Post by vette76 »
i would let u kno but i had .50 over and u have stock rite?
87' spree (SOLD
12' wrx
ferchja
Post by ferchja »
Correct, mine is stock.
burnt_toast
Post by burnt_toast »
if you still need to know, i can check out my box where i have the stuff from my last rebuild. i dont think i threw away the ring box so it may have the part number on there. let me know.
projects galore :nerd:
nester
Post by nester »
I can get you the part number for stock rings, but it's in my other car. I'll check when I get home tonight.
ferchja
Post by ferchja »
Thanks guys! Once I see what part numbers worked for you, I will be more confident to return the other one.
Jeremy
burnt_toast
its in the middle of the night, but i decided to go find that box, lol.
i got the rings from the dealership, so this should be the stock #:
13011-GAB-305
tell me if thats one of the ones you got.
ferchja
Post by ferchja »
Yep, that is what I think the replacement number is. I have the 305s
burnt_toast
ok cool, glad i could help u out.
