spot my errors...
spot my errors...
ok so i just posted some picture tutorials in the Advance Tech Docs part of this site. I know after working on them for so long i know no matter how many times i read it im going to miss my errors. and since you guys cant point out my errors there just post them here and ill fix them.
Or if theres any tips you want me to add. or if one of my facts is wrong. just please point it out and ill try to fix it.
''How to Install a Bore Kit''
''How To Install a Gear Set.''
"How to Install a New Center Spring"
"How to Check the Rollers for Flat Spots."
"How to Clean your Carburetor.{easy}"
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
Piston Rings
You might wanna modify the part where you describe installing the rings, then the piston into the bore. Chances are that if you need a "how-to" to install your bore you may not be too observant that the rings have to fit in the ringlands at ~10 and 2 to lock them in place properly. And if they didn't complete that step then putting the piston into a well oiled bore means nothing. It may even result in a broken ring once frustration sets in.
2000 Honda Dio
Malossi 72cc Bore
28mm Oko Carb 45 Pilot & 132 Main
Phongeer Long
9 to 1 Gears
Parmakit Variator
1500 RPM contra spring
Kuka Clutch w/Polini green springs
Koso Digital Tachometer w/CHT
Malossi 72cc Bore
Phongeer Long
9 to 1 Gears
Parmakit Variator
ok ill make sure to add that to it tonight. i also just realized that i didn't put anything along the line of 'when putting the piston in the > or EX faces the exhausts port. Ill have to update that when i get back from work.
Just to let every one know again, they all are up. If you have a moped that can be modded you might want to take a peek.
Also- Stop my errors! i cant seem to see any where were i messed up. but i know theres got to be something. Point them out and ill fix them.
Tips?
If you have any tips that you would like me to add to it let me know and i will. Im sure there is ways of doing it that are different from mine.
Tips?
Agreed!Kenny_McCormic wrote:f*** off, quit wasting bandwidth.stillspeeding wrote:Post the "how to rob a bank" article, this may fix the * poor michigan reputation for building half * projects
Honda Elite SA50-S
Stock motor, 9:1 gears, Kelli High speed pulley=a top speed of ?? Maxed the speedo out if that counts..average 45 mph
average 85 mpg
average 85 mpg
there isnt anything we can do about him. We ban him and he just comes right back.
Its happen once before.
i guess we all just have to deal with trying to understand what he is saying and deal with is stupid comments about us.
