Spree w/o air filter...starts then dies...
tlcbob
Post by tlcbob »
I got an 86 spree from a guy that didnt take care of it(for $250). It is missing the air filter...can it run without it until I get one? (to set idle etc not to ride around on) also where can I get a few of them?
I havent taken off the carb yet (I'm a rookie...this is my first mechanical project) It will start then die after about 10 seconds. I did change the oil and fuel, cleaned both filters an lines. Fuel diaphram seems to work...
Any ideas? Thanks.
vette76
Post by vette76 »
if there is no filter that is the problem. i guarentee when u get a filter it will run perfect.(or at least help u if it doesnt)
as to where to get a filter go to www.powersportpro.com
87' spree (SOLD
12' wrx
usdthrone23
Post by usdthrone23 »
weres a good place to find a clutch for my 85 ? mines worn
vette76
Post by vette76 »
same place. they have everything.
87' spree (SOLD
12' wrx
usdthrone23
theres about 10 things under clutch, do i need to fully replace it or what parts should i order ? heres a link http://www.powersportspro.com/trcatalog/
vette76
Post by vette76 »
just the shoes. email drichardson@core.com he will have it used but cheap.
87' spree (SOLD
12' wrx
burnt_toast
Post by burnt_toast »
when i was fixing up the spree when i first got it, it had no air filter. after i got it working, it ran fine w/out a filter, till like past 1/2 throttle. so theoretically ur setup should still work, but it helps a lot to have a filter.
projects galore :nerd:
mikehailwood
Post by mikehailwood »
My Spree would also start, run briefly, then die. I had a new air filter so, for me, the air filter was not the cause of this symptom. I had a blocked idle jet which when cleaned out cured my problem. I subsequently had the same problem and again found the idle jet blocked. With new lines and a fuel filter I never had to clean the idle jet again.
