85 spree won't start
stoneluv32
I rode it around the corner to the store. Stopped and started again to get home. It had been working normally before this and a couple of hours later it won't start. Plenty of compression with finger over hole. I put in a new sparkplug and put in a capful of gas and it started for a split second burning off the fuel and then dieing. Air filter is fine. It has fuel flowing from the bowl to the carburator, the bystarter doesn't work to start it when removed as i've heard it might to check for a faulty one. The strangest thing is that it makes the same starting noice when the sparkplug cap is off as when it is on. It sounds like it wants to turnover, but it just can't, so I'm thinking fuel, but the sparkplug cap thing is throwing me off. Thanx for your help.
stoneluv32
stoneluv32
I am in the process of cleaning the carburetor, valve spring, fuel lines, the auto fuel valve and I have run into a couple of speed bumps. First, where is the strainer? It doesn't appear to be in the fuel valve. Is it part of the assembly where the fuel valve screws on? Should it drop out or something? Second, the valve spring bends a bit and seems tight. Is this normal? Thanx guys
stoneluv32
OK...carburetor is cleaned and rebuilt, valve assembly and fuel lines are clean, but the auto fuel valve has what seems to be a clog in the lower stem. Is there a screen or something in there? I'm afraid to poke something in there as I have already soked it with the carburetor, sprayed jets of air through it and it is still clogged. A little air goes through and moves something in there, but it is obstructed. Also, for the valve spring assembly, does the spring go all the way down and seat on top of the retainer or is there supposed to be a small gap. The spring won't go all the way down because it gets stuck between the throttle cable and the throttle valve. Should I pull or push it down to seat it against the retainer? Sorry for all the questions, I've done as much as I can do on my own. Thanx
stoneluv32
stoneluv32
http://www.youtube.com/watch?v=TF9drhTNrRk This is the link to youtube. you have to copy and paste as my linkinkg skills really suck.
stoneluv32
I dumped gas in where the sparkplug goes and she started up breifly before revving to a max and dying becuz I screwed up the throttle valve assembly. It's crunching and sticking. That can be done later I suppose. But I guess the problem is no fuel. The fuel is not coming out of the line at all, but like I said, there was fuel in it before I pulled the line. I'm pretty close to setting the thing on fire on purpose.
stoneluv32
