Final drive fluid/ gear oil or 10w-40?
What do you guys use? I drained mine and it was gear oil , looked in the book and it says 10w-40 I will do what the book says, but It was 100%gear oil that I drained. super thick and no mistaken the smell. What do you guys use?
- chevyguyjay
thats to thick. it will slow you down. allot of people put thicker s*** in there thinking its what belongs since its gears. how ever 10w30 or 10w40 is what you should put in there.
I talked to a guy at honda about it.
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
- No_Stopping_A_Spree
- chevyguyjay
3 words Royal Purple Gear Oil
ok that was 4
but just use it those gears work to hard to use motor oil,
gear oil has ep additives (extreme pressure), which is usually a sulfur/zinc/moly mishmash, hense the * smell of non syn. gear oil
oh and no sludge of death when its cold outside
ok that was 4
Green for tha' money gold 4 tha honeys
- MichiganEd
- chevyguyjay
- MichiganEd
We used to call stock oil fish-oil, because in the 80s, the oil smelled fishy and was only good for break-ins.
Even if your bike is stock, treat it to some synthetic multi-weight gear oil. Use the same thing that dirt bike guys use in your area.
If you're running a performance moped, then break in with regular gear oil and then go synthetic. Good synthetics have 3x the shear strength of natural petroleum oils = less friction, less wear, better performance and longer life.
You don't have to change gear oil very often, so it's worth the few extra bucks.
