y not, lets start another one!
chevyguyjay
Post by chevyguyjay »
ok, heres another spree in doin for my buddy. hes got a 85 aero50 engine that hes puttin on it. hes waitin on the goodies for it now. :wink: bore kit, high speed pully kit,etc.......ill keep everyone up to date on this project too. :wink:
~2004 Geely Fashion~
Dac
Post by Dac »
what type of tire is that?!?!?!
oh and what year is the spree?
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
burnt_toast
Post by burnt_toast »
Dac wrote:what type of tire is that?!?!?!
offroad dirt bike tire.. 86?
projects galore :nerd:
chevyguyjay
yep, its a 86. so heres some of the performance parts my buddy got for the engine. still a long way to go on this bike, but will keep up dated on the progress. :wink:
chevyguyjay
im wondering what kind of speeds this engine will put out? anyone have any ideas? just curious. :wink:
stillspeeding
Post by stillspeeding »
Dude, without those 8 to1 gears you will blow that bore :oops: been there done that 25yrs ago!
Dac
Post by Dac »
stillspeeding wrote:Dude, without those 8 to1 gears you will blow that bore :oops: been there done that 25yrs ago!
there is tons of bikes out there with out gear changes that run fine. Sure a top speed it wont last as long as some one with a gear change.
edjo
Post by edjo »
Not to mention 25 years ago you weren't even alive!!
88 elite SA50
07 DRZ436sm
05 FJR1300a
05 Dr200se
chevyguyjay
hmm......i find it hard to believe that ill "blow" the bore if i dont get these gears. could u please explain in good detail how this will happen?? 8)
Post by Kenny_McCormic »
There is a slight chance of it over revving due to being underloaded and breaking the rod. Same reason why you dont rev high performance bikes on the stand.
Dac
Post by Dac »
by blow he means smear, or toast the cylinder. (ruin) its because with out a gear change you have to run it WOT just to hit normal speeds. with a gear change you can hit those speeds at lower rpms.
WOT on anything over a long period of time is bad for it. So what he is saying is kinda true. But if you take 2 of the same bikes, one stock gears and one after market. and run them on the stand at full rpm's for a huge amount of time. they will both go out at about the same time.
A bike with a gear change will appear to last longer because they get more miles. but this is false. if instead of miles you go by time at high RPM's, there about the same.
yeah, stillspeeding, what you got to say to that????
chevyguyjay
i dunno.......i just find this false that this will happen. my opinion of corse. i just dont c it. how can u possibly over rev the engine when it all ready has a rev limiter on it? if what dac says is true.... my bike should of blown up a long time ago, cause i ride wot all the time. no offense to anyone on this topic. :wink:
wikked_spree57
Post by wikked_spree57 »
I toasted mine at WOT, but that's cause I just redid the top end, and ran wide open after only 25 miles of break in, couldnt stand taking an hour to commute a 10 minute ride to the library, so I rode home WOT and it shattered the piston when I tried to start it again.
1994 BMW 525i 5 speed BEAMER TIME
1983 Yamaha XC 180 - Bought barn fresh in mint condition and 254 miles. Best bike I ever owned :)
chevyguyjay
wow, thats interesting. what kind of kit did u have? was it like the my buddy has? :?
Dac
Post by Dac »
his was a stock spree motor.
any yeah stock cylinders can handle high rpms better. i dont know why. But i have gone though enough cylinders, stock and bored, to know the basics of whats going on.
Stock cylinders are really hard to burn up (unless your just stupid) but bore kits dont last as long. But the power is so worth it.
