pg long
- monkeywrench
pg long
i was wandering if this would be a good pipe for a 70cc kit or does it have to be stroked?
and what does the pg yoshima pipe fit just the 72 to 85cc kits just wanted to now becouse im screamin more power now im all broke in perfect.
any pipe refs would be greatly apriceated.
- burnt_toast
- monkeywrench
- burnt_toast
It is ~72cc due to the displacement difference after the extra base gaskets. To take advantage of the full stroke I would have to rework the head and add head gaskets.maddog wrote:Hey toast, if you are running a mini stroker- its not 72ccwhats up with that
a leovince sp-3 for the price will work just fine.
projects galore
- burnt_toast
- monkeywrench
- burnt_toast
Not as loud as you would think, its a nice deep rumbly tone that sounds to me like a revvy straight pipe 4stroke almost, the real bulk of noise comes from the carb.monkeywrench wrote:Thanks guys for the replies. the price fits my budget but i want 844-1 gears so i dont burn it up so it might be a couple of paycheck though.
i hope i dont get noise polution tickets though becouse i heard there very loud. but power is the most inportant thing i guess.
projects galore
- monkeywrench
- monkeywrench
Well i got my pg long in the mail with other thigs to hop her up like better ramp plate for take off 1500 rpm center clutch spring and 844/1 gear set to go along with my 70cc big bore kit and 24mm oko carb. any ideas on speed increas. with the gear cchange and also wanted to know how do you get the specail tools for disasimbleng the block so i can biuld up my other dio motor
money is no option do to good hours at work
