rusty gas tank question
dukemartini
Post by dukemartini »
My 87 se50 sat outside for 10 years before i got it and the gas tank is covered in surface rust on the inside.
has anyone had any experience with coating the inside of a gas tank and how hard easy was it? i know this is a fairly common thing done to motorcycle tanks but i have no experience with it.
87 Honda Elite S-BASKET CASE PROJECT
88 Honda SB50P-sold but not forgotten
mopedman
Post by mopedman »
well one trick is to go get like 5 gals of gas and some new bolts and nuts and put a gal in and some bolts close it swish around for 5 min and repeat 4 or 5 times and it will be good
2005 Yamaha Zuma
1985 Honda Spree
1978 Honda Express
jstone
Post by jstone »
Unless the nuts/bolts make a spark... Noiseguy did a post on how to clean a gas tank out.
dukemartini
jstone wrote:Noiseguy did a post on how to clean a gas tank out.
Any idea where that post is? I've done a couple of searches and can't find anything.
CharlotteSpreeRider
Post by CharlotteSpreeRider »
dukemartini wrote: Any idea where that post is? I've done a couple of searches and can't find anything.
http://www.hondaspree.net/phpBB2/viewtopic.php?t=5
dukemartini
thanks
Man that is an OLD post. Technique worked great for me, though, and the tank's still clean after a few years.
I've read up on tank coating... unless you have holes through the tank (and can't get a new one) it's just not worth it... carb gets filled up with tank sealer instead of rust.
Curly
De rusting a tank
Post by Curly »
Duker,
I just de-rusted my tank with a product called Evapo-Rust. You can purchase it online or at most Autozone stores. It works real well and can be reused. When you are done using it in your tank pour it through a coffee filter back into the container to save it for future. Be sure to use a good degreaser before you let the Evapo-rust sit for a few days.
-Curly
I have a Honda Squash, purchased originally in Japan. I also have a Motobecane Moped.
dukemartini
I'll check that out, thanks Curly
