I have another reed holder that I'm currently cleaning the old gasket off of. Hopefully this is the problem. It was sputtering badly. It's gotten worse and worse. Like it used to run at 30 MPH wide open and sound like it was really working. Now, it will only get up to 30 on a downhill, and it sputters when it goes faster than the motor would pull it on level ground.
I've got a reed holder that is in MUCH better shape that I've cleaned up. I'll put in on in the morning, and hopefully that fixes the problem.
At this point, it's either that, or I dissolved the baffles in the muffler by letting it soak in drain cleaner overnight and need a new muffler.
-aseigler
