Chemical Cleaning a Muffler
I would like to clean my muffler, but i am not skilled enough to do it with a flame. If someone could give me a walkthrough on how to clean a muffler with chemicals (and what kind). Thanks for the help, this forum is awesome.
1984 Spree
I use oven cleaner...one can is plenty.
I let it sit for half a day or so and then rinse it with the garden hose really good...both directions.
I let mine sit for a day upside down to get the water to drain and still had a bunch in there...so I did use the BBQ method to get the last of the water out.
Woks great for me!
Robert
Woks great for me!
Robert
"I can't drive......35!"
Here is what i did today... with pictures because sometimes it helps...
"Okay then... if you do this, wear gloves and a *full*face*mask*. Please! Lye is used to dissolve bodies in graves to hide the evidence. It will burn your skin quickly. Don't let it contact aluminum either as it reacts violently. Please be careful.
I filled a tall, narrow plastic trashcan with a couple of bricks as filler (sideways)"
"and added the gallon of hydroxide solution. I followed that with two gallons of hot water. Then I submerged the muffler, tailpipe first, so that it was under the solution up to the pipe portion (which I had already brushed out pretty well). I gently tilted this around a bit to get the solution to fill any air pockets and let it sit for a while. "
"Every thirty minutes I pulled out the muffler and let the lye drain from the tailpipe. It was black like ink with all the loose carbon! I repeated this over the course of about 4 hours. It's a slow chemical reaction - be patient. "
This is after 30 minutes..
after 60 minutes..
A few hours later...
notice how black the water is!
"I used a garden hose and ran water in forward through the entire exhaust, then backwards through the tailpipe, etc. Just flush the heck out of it." Im letting it drip dry overnight and if any water is left, I'll use a propane torch to boil it out.
Hope this helps.
-Jason
after 60 minutes..
Hope this helps.
-Jason
