alright guys
unclebeaner
alright guys
Post by unclebeaner »
im sure you get a milion people saying "how do i make my spree faster" well as much as i dont wanna be that guy im going to have to break down and do it,
i have a 86 spree runs great but thats no fun. im looking down the road of a big bore kit ect. i have a wealth of knowledge on working on quads,bikes,ect. what kinda kits,carbs and trans set ups are you running. i also have a elite 80(i think) that was a craigslist speical. just wanna the baddest spree on the block. :lol: thanks gygs
jstone
Post by jstone »
Then buy a Dio motor and put it in your spree lol. There isn't much you can do to make yours go significantly faster due to the lack of gears. I don't think there is a big bore kit either, i've heard of them before but its one of those urban myth things. Honda sells over size pistons and rings up to .050 over so the best you can do is bore the existing cylinder. Read around. There is plenty of posts describing the other things you can do.
unclebeaner
jstone wrote:Then buy a Dio motor and put it in your spree lol. There isn't much you can do to make yours go significantly faster due to the lack of gears. I don't think there is a big bore kit either, i've heard of them before but its one of those urban myth things. Honda sells over size pistons and rings up to .050 over so the best you can do is bore the existing cylinder. Read around. There is plenty of posts describing the other things you can do.
dio motor? alright i have several mopeds and wanted to get a little extra out of one of them
Post by Kenny_McCormic »
List what you have (year and model #) and I will tell you what can be done to all of them.
jstone
Post by jstone »
What are your others?
Dac
Post by Dac »
a dio is a 94-01 honda elite 50.
a dio motor is highly modable. you can buy bore kits, carbs, tail pipes, gears, everything.
a spree motor is basically a dead end when it comes to tuning. It really cant be made faster.
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
It can be made faster but 40 or so is the cutoff and you need a machine shop along with some d*** good dremel skills to pull it off.
