Chemical Cleaning a Muffler
Slinky
Post by Slinky »
I would like to clean my muffler, but i am not skilled enough to do it with a flame. If someone could give me a walkthrough on how to clean a muffler with chemicals (and what kind). Thanks for the help, this forum is awesome.
1984 Spree
dr.ona
Post by dr.ona »
I use oven cleaner...one can is plenty.
I let it sit for half a day or so and then rinse it with the garden hose really good...both directions.
I let mine sit for a day upside down to get the water to drain and still had a bunch in there...so I did use the BBQ method to get the last of the water out.
Woks great for me!
Robert
"I can't drive......35!"
Slinky
Post by Slinky »
What would be the Ideal chemical to clean it with?
1984 Spree
Slinky
Post by Slinky »
Could anybody give me a really good walktrough for this? I couldnt find one through the search.
Thanks a bunch.
1984 Spree
dukemartini
Post by dukemartini »
87 Honda Elite S-BASKET CASE PROJECT
88 Honda SB50P-sold but not forgotten
Post by Kenny_McCormic »
Plug one end, hang it from a tree or something, fill it with chem, let it sit, rinse it out multiple times, and run it to boil the remaining water out.
Slinky
Post by Slinky »
Awesome that link should help me out alot, thanks guys.
1984 Spree
Jenesis
Post by Jenesis »
dr.ona wrote:I use oven cleaner...one can is plenty.
Sounds like a good idea.
Would (car engine) degreaser spray work?
mopedman
Post by mopedman »
probably not, because the carbon is like cooked on the sprees muffler
2005 Yamaha Zuma
1985 Honda Spree
1978 Honda Express
Jenesis
Post by Jenesis »
Good point.
Oven cleaner it is.
1985 NQ50 "Nifty 50"
Samargh
Post by Samargh »
Jen, were you thinking of Simple Green? I may give it a try as its on the "to do" list
BTW, what part of NZ are you sitting in?
Jenesis
Post by Jenesis »
Nah, I'll probably just bust out some Mr. Muscle from under the sink when the wife's not looking. :wink:
I'm in good old Masterton.
jwasciuk
Post by jwasciuk »
Here is what i did today... with pictures because sometimes it helps...
"Okay then... if you do this, wear gloves and a *full*face*mask*. Please! Lye is used to dissolve bodies in graves to hide the evidence. It will burn your skin quickly. Don't let it contact aluminum either as it reacts violently. Please be careful.
I filled a tall, narrow plastic trashcan with a couple of bricks as filler (sideways)"
"and added the gallon of hydroxide solution. I followed that with two gallons of hot water. Then I submerged the muffler, tailpipe first, so that it was under the solution up to the pipe portion (which I had already brushed out pretty well). I gently tilted this around a bit to get the solution to fill any air pockets and let it sit for a while. "
"Every thirty minutes I pulled out the muffler and let the lye drain from the tailpipe. It was black like ink with all the loose carbon! I repeated this over the course of about 4 hours. It's a slow chemical reaction - be patient. "
This is after 30 minutes..
after 60 minutes..
A few hours later...
notice how black the water is!
"I used a garden hose and ran water in forward through the entire exhaust, then backwards through the tailpipe, etc. Just flush the heck out of it." Im letting it drip dry overnight and if any water is left, I'll use a propane torch to boil it out.
Hope this helps.
-Jason
Dac
Post by Dac »
do you mind if i post that in the "tech doc' part of this site?
that is really helpful.
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
There is no need to boil it out with a torch, just put it on the bike and go riding for 15 minutes.
