Making a Kickstart?
Making a Kickstart?
So if I drilled a hole in my side case, would it be possible to put a kickstart on my spree? ( I know this seems like a bad idea, but i just want to know)
1984 Spree
- CharlotteSpreeRider
I wouldn"t be so gung ho on that kickstarter. The sprees that have it on there is mainly for a backup when the electric starter does not work or battery is dead. They are rather fragile and can break if enough force is applied. I would invest my time and money on fixing that electric starter of yours.
Yea, I damaged (it still works if you hit it just right) my kickstart when i got * off at the bike at age 10 and I was a weak * at the time. Its definitely not something you should "kick" more like a gentle shove.
No, you can't just drill a hole in the sidecover. You'd never get the right placement without a mill, and the hole wouldn't be reinforced properly.
