smithjord
Post by smithjord »
I have a 84 spree and my buddy has a 87 elite and it is way faster, is mine supposed to be that much slower and if not what could be the problem. Is there any way to make it faster without boring any or cutting the head .020 just sounds like hard work that could go really bad. i just want to buy a part or a big bore kit. ANy ideas would be very helpful I am just sick of being way behind my buddies. Also it goes like ten Mph up hills is that normal, Cause I want to bring it home but its really hilly where i live. Sorry for all the question and thank you
chevyguyjay
Post by chevyguyjay »
do an engine swap. u cant do much to a spree engine. :wink:
~2004 Geely Fashion~
Post by Kenny_McCormic »
Drill two muffler baffels and grind the restriction out of the intake tube.
frank63
Post by frank63 »
are there any instructions on how to modify the intake. pictures would be great
Pull it off and you will immediately understand where the problem is, smooth out the transition with a dremel.
Does anybody bother actually reading the advanced tech docs anymore?
Farfignugin
Post by Farfignugin »
apparently they don't even read the "Before You Post" topic.
Scooters I have:
1985 (mostly unmodded) Honda Spree
2007 Honda Silverwing
Elite1998
Post by Elite1998 »
noiseguy wrote:Does anybody bother actually reading the advanced tech docs anymore?
I do :).. they help alot!
Honda Elite SA50-S
Stock motor, 9:1 gears, Kelli High speed pulley=a top speed of ?? Maxed the speedo out if that counts..average 45 mph
average 85 mpg
seacook
Post by seacook »
Go slow man...there's all sorts of class you can aquire that way!!!
