spot my errors...
Dac
spot my errors...
Post by Dac »
ok so i just posted some picture tutorials in the Advance Tech Docs part of this site. I know after working on them for so long i know no matter how many times i read it im going to miss my errors. and since you guys cant point out my errors there just post them here and ill fix them.
Or if theres any tips you want me to add. or if one of my facts is wrong. just please point it out and ill try to fix it.
''How to Install a Bore Kit''
''How To Install a Gear Set.''
"How to Install a New Center Spring"
"How to Check the Rollers for Flat Spots."
"How to Clean your Carburetor.{easy}"
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
jeremydde
Piston Rings
Post by jeremydde »
You might wanna modify the part where you describe installing the rings, then the piston into the bore. Chances are that if you need a "how-to" to install your bore you may not be too observant that the rings have to fit in the ringlands at ~10 and 2 to lock them in place properly. And if they didn't complete that step then putting the piston into a well oiled bore means nothing. It may even result in a broken ring once frustration sets in.
2000 Honda Dio
Malossi 72cc Bore
28mm Oko Carb 45 Pilot & 132 Main
Phongeer Long
9 to 1 Gears
Parmakit Variator
1500 RPM contra spring
Kuka Clutch w/Polini green springs
Koso Digital Tachometer w/CHT
Dac
Post by Dac »
ok ill make sure to add that to it tonight. i also just realized that i didn't put anything along the line of 'when putting the piston in the > or EX faces the exhausts port. Ill have to update that when i get back from work.
Dac
Post by Dac »
ok i fixed that. any other things i messed up?
Post by Kenny_McCormic »
You might want to add that when putting the hed back on tourqe al the bolts down in an X pattern kinda like changing a car tire.
Dac
Post by Dac »
ok i just got 'how to install a gear set' up. any one see any errors in that one?
I havent had mine apart yet but isnt the clutch spring loaded and liable to fly apart if your not holding on?
Dac
Post by Dac »
give me a day or 2. one of the tut's im making is how to change the clutch center spring. i just got to type it all out.
Dac
Post by Dac »
ok, how to install a new compression spring is up. Kenny_McCormic , i got this one up so fast for you.
Dac
Post by Dac »
Just to let every one know again, they all are up. If you have a moped that can be modded you might want to take a peek.
Also- Stop my errors! i cant seem to see any where were i messed up. but i know theres got to be something. Point them out and ill fix them.
Tips?
If you have any tips that you would like me to add to it let me know and i will. Im sure there is ways of doing it that are different from mine.
strapped9
oops
Post by strapped9 »
you might mention the upper rod bearings in the installing bore thread. everything else looks great. fantastic job with these how to's.
stillspeeding
Post by stillspeeding »
Post the "how to rob a bank" article, this may fix the * poor michigan reputation for building half * projects :cry:
stillspeeding wrote:Post the "how to rob a bank" article, this may fix the * poor michigan reputation for building half * projects :cry:
f*** off, quit wasting bandwidth.
Elite1998
Post by Elite1998 »
Agreed!
Honda Elite SA50-S
Stock motor, 9:1 gears, Kelli High speed pulley=a top speed of ?? Maxed the speedo out if that counts..average 45 mph
average 85 mpg
Dac
Post by Dac »
there isnt anything we can do about him. We ban him and he just comes right back.
Its happen once before.
i guess we all just have to deal with trying to understand what he is saying and deal with is stupid comments about us.
