Nos on a moped
Post by Kenny_McCormic »
I would still go wet, if you only want a small dry shot i can show you how to do that for A LOT cheaper than $200.
mopedman
Post by mopedman »
i probably will only use the nos like a few times any way it is more of just to say I've done it and it will look cool to have nos on a moped
2005 Yamaha Zuma
1985 Honda Spree
1978 Honda Express
Well then, go buy a 12 gram co2 tire inflater and add a hose to it running to the intake (JB weld, a valve stem, and a hose barb should work, you might want to add a flow restrictor of some sort. dont forget a box of creme whip cans. You may need to add a spacer and do a little bit of filing on the inflater to get the 8 gram NOS shot to work. BTW if you do this the engine WILL PROBABLY NOT last long.
http://www.koolpages.com/potatohell/nondestructive.html here is a guy who did what im describing to a goped.
Last edited by Kenny_McCormic on Mon May 19, 2008 5:13 pm, edited 1 time in total.
mopedman
Post by mopedman »
i already ordered a nos kit. from summit
2005 Yamaha Zuma
1985 Honda Spree
1978 Honda Express
burnt_toast
Post by burnt_toast »
mopedman wrote:i already ordered a nos kit. from summit
nice keep us posted on how you rig it. :)
projects galore :nerd:
darat
Post by darat »
lol ya u might be able to beat my zuma
fireblade
Post by fireblade »
If you're planning to run a dry kit on a scooter, you'll have to fatten up your baseline jetting. A mate of mine had nitrous on his scoot. The extra flow through the carb (The nitrous gas) will pull more fuel into the engine, but since nitrous oxide had more oxygen molecules that plain old air does, you'd run a risk of leaning out. A nitrous assisted lean out can destroy pistons before you could even back off the throttle. Put your needle in a drill, and use a bit of fine sand paper to make the tip a bit smaller to richen up the mixture.
HONDA NQ50 "FIREBLADE"
fireblade wrote:If you're planning to run a dry kit on a scooter, you'll have to fatten up your baseline jetting. A mate of mine had nitrous on his scoot. The extra flow through the carb (The nitrous gas) will pull more fuel into the engine, but since nitrous oxide had more oxygen molecules that plain old air does, you'd run a risk of leaning out. A nitrous assisted lean out can destroy pistons before you could even back off the throttle. Put your needle in a drill, and use a bit of fine sand paper to make the tip a bit smaller to richen up the mixture.
If he dumped $200 on NOs he can afford a $20 small metric drill set.
stillspeeding
Post by stillspeeding »
Why would you need nos? is it cuz you can't afford to build a real full stroker :lol: Mich-a-kids, home of the half * builds :lol:
stillspeeding wrote:Why would you need nos? is it cuz you can't afford to build a real full stroker :lol: Mich-a-kids, home of the half * builds :lol:
If your so * rich lets see your s***, pics or shens b****.
tru72
Post by tru72 »
i have done a few dry set ups before on 72cc .. Pretty nuts when you hit the button. Feels like you downshift a gear and it goes! Alot of fun.but IMOP I would defiantly do a wet set up. Thats what im going to do for my drag bike soon.
have fun!
D
burnt_toast
Or just buy some jets.. :lol:
burnt_toast
tru72 wrote:i have done a few dry set ups before on 72cc .. Pretty nuts when you hit the button. Feels like you downshift a gear and it goes! Alot of fun.but IMOP I would defiantly do a wet set up. Thats what im going to do for my drag bike soon.
have fun!
D
Awesome, pics? What kind of problems did you see with the dry set ups, did it run much leaner or did jetting carb keep it safer?
darat
Post by darat »
ya b/c ur so cool b/c u have a s*** load of money to blow on ur peds THEY DONT MAKE ANYTHING FOR IT SO WHAT DO U WANT HIM TO DO.
Anyone thought of making a ghetto-style NOS setup using an airbrush full of gasoline pushed through by NOS?
Admin, Hondaspree.net
