2 stroke or 4 stroke??????
Jacobusmaximus
Post by Jacobusmaximus »
I have a 99' sr-50 "Dio" And Is the d*** thing two stroke or four stroke because it sounds like a two stroke but it has a seperate gas and oil tank and the oil tank takes some 5w-30 stuff???
Yamaha Aerox 50 WANTED!
Post by Kenny_McCormic »
Its a 2 stroke, that tank is for 2 stroke injection oil so you dont have to premix the gas. LOL, you talk about al these upgrades and dont even know what engine you have.
Jacobusmaximus
assasas
I like engines and i'm tring to learn. So could I start using premix and what would i have to do to the oil line? Kink it or someting? Also would I have to start using the same oil i put in my weedeater?
Dont plug it off, dont use weed eater oil in it, use honda GN2 injection oil and that oil only as you clearly dont know what you are doing so just keep it simple.
Jacobusmaximus
what code, ex: 5w-30? where do i get it? take in mind im 15
GIJoeBob
Post by GIJoeBob »
I bought my oil at Walmart. Just make sure it says that it works for 2 stroke injection systems.
Jacobusmaximus wrote:what code, ex: 5w-30? where do i get it? take in mind im 15
Those codes are for 4 stroke engines, i dont think there is a code for injector oil.
Dac
Post by Dac »
yeah,
its not like 10w 40 or anything like that. any...
"2stroke injector oil"
... will do the trick just fine. But i highly recomend using honda brand 2stroke injector oil. That stuff works awesome.
as for capping it off and premixing, My advice, Dont.
But if you want to, here is the things you have to do....
1- remove the oil tank.
2- remove the oil pump and grind teeth off it.
3- Replace oil pump after it has been modded.
4- cap off the oil line hole on the carb.
I switched to premix for a while but i ended up switching back. (new pump). The stock oil injector works so great there is no since in taking it out.
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
burnt_toast
Post by burnt_toast »
removing oil pump gear may be easier than grinding teeth off, its press fit heh :lol:
projects galore :nerd:
justinnielsen01
Post by justinnielsen01 »
why do you even want to switch to pemix. its a pain
mopedman
Post by mopedman »
or you could take the oil pump out and buy the plug that gos in its spout from vt
2005 Yamaha Zuma
1985 Honda Spree
1978 Honda Express
