derestricting elite
gobucks
derestricting elite
Post by gobucks »
hi, just picked up a 95 honda elite SA50 and i am just wonderin what i can do initially to get it movin with a higher top speed?
Dac
Post by Dac »
you talking about adding parts?
or are you talking about taking stuff off? If so, This is as deresticked as you are going to get.
I would check your compression if you did all of these and your bike is not going 35.
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
gobucks
Post by gobucks »
there was no washer in the exhaust, i took off the plate on the back of the crankshaft pulley but haven't done anything to the air intake or changed the jet on the carb, and it still goes 28mph. does this sound normal?
what is the compression supposed to be at?
Dac
Post by Dac »
compression should be like 120.
100 is ok.
90 or below is time for rebuild.
