New petcock
Mackeral61
New petcock
Post by Mackeral61 »
My new petcock just arrived for my spree....maybe a problem...description says NEW VACUUM PETCOCK HONDA ELITE 50 SA SE 50 NQ NB SPREE.....I kinda figured it was a universal one for all those above brands....its a bit smaller than the original but shaped the same....problem is....I was checking it out and tried pulling air through the upper nozzle by mouth ( the one that gas flows from tank to carb) and no air pulled through where it does on the old one.
Suggestions?
Post by Kenny_McCormic »
Vacuum must be applied to the bottom barb before it will flow fuel.
Mackeral61
Thanks so much....one more thing...when people speak of using a dremel tool on intake manifold..are we speaking of the part that is closest to the carb...round end?
One note....on the old petcock....gas flowed through the upper tube outlet all the time.
Intake manifold is the tube between the carb and engine, you have to drop the motor out and pull off all the engine plastics to get to it.
Mackeral61
I've already gotten to it w/o dropping the motor...if its the tube (90 degree goose neck thingie) that attaches to the carb on one end ....then bends downward to the motor with the reeds on the bottom side(which is squarish in shape. on the round side(next to the carb) which is seperated by a thick gasket with an o ring inbedded in it....I can see where some material can be removed a bit to open it up some...on the inside it angles inwards some.
CharlotteSpreeRider
Post by CharlotteSpreeRider »
It's actually the left half of the engine, the part that the intake bolts onto that can use alot of dremel help. There are jagged parts in there where the vertical metal part that splits the opening in two and otherwise appears to do nothing at all is. Doing it right and making sure you don't get metal bits in the crankcase absolutely requires splitting the crankcase. It's much easier to see and grind the bad stuff away from the inside of the left side of the crankcase.
-aseigler
Mackeral61
Thanks for clarifying that....I was about to get the dremel to that gooseneck thing attached to the carb....really glad you posted that before I did..prolly just saved me a major headache
The gooseneck thing is all I did, never messed with the case although there is room for improvement. The round to square transition on the manifold is absolute s***, smooth it out with a dremel, you want a rough finish here so dont polish it or anything.
