1986 Honda Spree that will not continue to run
umgrman
Post by umgrman »
Greetings,
I just purchased a 1986 honda spree over the week-end and it was working fine Sunday and monday I made several trips going 30-35 without difficulty. until Tuesday morning on my way to work I was cruising along at 25-30 when the motor just stopped. I could start it again but when I tried to accelerate at all it quit. the gentlemen I purchased it from stated something about taping up one of the intake ports and retrying. I am a novice here. any suggestions on how to proceed??
Post by Kenny_McCormic »
Clean the carb.
umgrman
Post by umgrman »
thanks we will try that
umgrman
Post by umgrman »
Well I cleaned the carb, as well as putting new oil and a new spark plug in. Only problem is, now I don't get anything( the battery turns over but it doesn't start.)
have any suggestions or advice as is to how i should handle this problem?
I'm still new at this sorta thing.
Mackeral61
Post by Mackeral61 »
It sounds a bit like what I just went through today after cleaning the carb out. Try squirting a bit of starter fluid in the air intake to jump start her a bit, then when she is running the vacuum will pull gas to the bowl. This is coming from a noob also that is learning fast by reading about every forum in this website between breaks on working on my 85 spree.
Elite1998
Post by Elite1998 »
Did you put the screws back in at the proper turns? Did you mess with the float somehow?
And starter fluid is very bad on these little engines..best not to mess with it
Honda Elite SA50-S
Stock motor, 9:1 gears, Kelli High speed pulley=a top speed of ?? Maxed the speedo out if that counts..average 45 mph
average 85 mpg
They are ALWAYS a b**** starting from an empty bowl. Put your fingers over the intake holes on the air box lid, this will generate enough vacuum to get it going.
