quick question
quick question
How do you get the magnetic thing on the side off ?
- burnt_toast
the magnetic thing on the right side of the motor. if figure if i take it off i can get the rod off and pison and then slidfe the rod and piston overthe jug using a ring compressor and then connect the rod back to the motor. thats the only way i figure i can get this thing to run, because i just cant slide the jug over the piston without breaking a ring. do yall think that will work or shouild i just take it to the dealer?
i always put the jug just over the piston. u can take the pin out of the piston and slide it in the jug just enough to cover the rings. then u can use the ports to slide the pin back in.
87' spree (SOLD
12' wrx
87' spree (SOLD
12' wrx
