I will get the primer code for you... it is down at my friends shop..jstone wrote:You told me in the other post that you used a flexible primer that you got from NAPA right? I had my local store call for me and they said that all they could order was some kind of adhesive that you put on before you paint that was like $84 a quart, so i said forget about it. What exactly did you use as a primer?
Edit: Was it one of these? http://www.napaonline.com/MasterPages/N ... &VehCode=N
I know if you have a local body shop that they can refer you to a place to get this flexible primer...
You can even get it in an aerosol can too!!
I just cant remember the exact name of it.. will get back with u on that..
