Just have a couple questions....
1. When drilling baffles in the exhaust, I wasnt paying much attention apparently and I let it drill through the outside of the muffler under that plate thingie. What damage would this cause and will standard muffler tape be OK to cover up hole.
2. I decided to do away with the oil resevoir and just use premix, and Yes I ground the teeth off the pump and plugged the holes with vacuum plugs. I'm using a premium synthetic 2 cycle oil mixed with the gas...is this OK or is something better?
Two questions...
- monkeywrench
tap the hole and then put in a bolt not to long though
here kitty kitty kitty
http://www.youtube.com/warmonkey80
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO!monkeywrench wrote:tap the hole and then put in a bolt not to long though
You will f*** up your crank volume by doing that, grind off gears or order a dummy only.
- monkeywrench
this is what i ment not the hole to the oil pump haha. ya i was just answering his first question.
