Spree did something goofy on the way to work today...
CharlotteSpreeRider
Post by CharlotteSpreeRider »
It is hotter than blue billy * here, like almost 100 degrees. Was heading in to work, down a long hill, almost hit 40MPH. Then as the road leveled out, the motor slowed down...35...30...25...20...15...pulled over. Bike idled great, but I gave it any throttle at all, it bogged and died within a second. Started right back up, but would only idle. Turned it off, sat under a tree on the side of the road for a couple of minutes looking around at things. Plenty of gas in the gas line. Nothing leaking. There was a bubble in the oil line between the pump and the intake that was not there before, not sure what's up with that, I'll have to check it when I got home. Anyhow, after sitting on the side of the road for like 5 minutes, it started up and would run like normal. I only went 25 the rest of the way to work.
I can only think of two things this might be:
1. Overheating due to running the motor faster than it is capable of running on it's own?
2. Oil pump can't keep up with consumption at very high RPM?
I'm not sure what happened, but it was really odd. It's never done that before.
-aseigler
mopedman
Post by mopedman »
yea ive never heard of that before it is odd
2005 Yamaha Zuma
1985 Honda Spree
1978 Honda Express
snikro
Post by snikro »
I think it could be both. The spree isnt really made to run 40mph comfortably I dont think (correct me if im wrong) so if youre doing that plus in 100 degree weather its probably not a good idea one way or another.
Check fuel flow... I've had this happen when the petcock stopped flowing fuel in the middle of a ride.
CharlotteSpreeRider
There was plenty of fuel in the line. I have Tygon lines, so I can see it easily, and that was the first thing I checked when I pulled over. It's just odd that it idled perfectly, but would die instantly with any throttle.
Thanks,
-aseigler
Post by Kenny_McCormic »
Overheated, hot motor runs lean and acts up. Hot air being thinner would also lead to lean out.
keithw
Post by keithw »
A long time ago in a galaxy far far away I went down a long grade on a hot day at wide open throttle on a friends scooter. About half way down it siezed up. After cooling it ran fine(lucky me). Doing that causes them to run way lean. Same hill at 3/4 throttle and closing the throttle for a few seconds every once and a while worked fine and was almost as fast.
keithw
chevyguyjay
Post by chevyguyjay »
thats exactly what happened. it over heated. my aero did that b 4. dont hold it wot for to long. :wink:
~2004 Geely Fashion~
CharlotteSpreeRider
Yeah, I'm guessing that is what happned. It is odd though. I only have a ~4 mile ride to work, and I was about 1.5 miles out when it happened. The motor had only been running for less than 4 minutes. That seems like a very short amount of time to overheat in. I also don't understand why it would idle just fine when it was overheated.
-aseigler
CharlotteSpreeRider wrote:Yeah, I'm guessing that is what happned. It is odd though. I only have a ~4 mile ride to work, and I was about 1.5 miles out when it happened. The motor had only been running for less than 4 minutes. That seems like a very short amount of time to overheat in. I also don't understand why it would idle just fine when it was overheated.
-aseigler
Same reason it idles fine when you first start it on a cold day but it bogs when you give it throttle.
CharlotteSpreeRider
Kenny_McCormic wrote:Same reason it idles fine when you first start it on a cold day but it bogs when you give it throttle.
Alright, you lost me dude. What is this reason you speak of?
If you ever let a spree idle for 10 minutes and pull the plug it will come out covered in oil and black, these idle rich.
