Standard spark plug size on an 89 Elite?
I've reached the stage where I need to remove the old spark plug and put in the new one on my 89 Elite. I tried the biggest metric socket I own, an 18mm, and it wasn't quite big enough. What size is the spark plug nut? 20mm? Bigger?
I've got a standard spark plug wrench, but that's not fitting...mopedman wrote:you can get a spark plug wrench at any auto parts store for under $10.00
Hey, is there maybe some sort of rubber boot around the plug? I can't see in there too well, but that would explain it not fitting any of my sockets.
Is the rubber boot removable without pulling off the shroud? The second bolt holding the shroud on is tucked behind the carb, and I don't really want to pull the carb off just to change a spark plug.Kenny_McCormic wrote:There is the plug wire and a rubber boot the seals the gap between the fan shroud and the plug.
You just pull it off, its kinda obvious. do you have the sidepanels off?
BTW you have some false info in those pics in your sig, a chanisaws oil tank does not auto mix, you put premix in the gas tank and bar oil in the oil tank (for lubing the chain, this part is usually automatic). A chaninsaws oil tank has nothing to do with engine oil.
