This is an 85 with 1400 miles on odo-to recap suspect no compression, carb clean, getting fuel but plug is dry, runs for a second with wd40 sprayed in plug hole...head has no carbon, piston has some,cylinder looks good, rings OK? Please help get it running![i
mg]
Thanks for helping...I stuck myfinger in the plug hole while cranking and felt No pressure-only some slight suction on the downstroke. Still can't figure how burn marks on side of piston got Below the rings???? Also is it normal to have carbon build up on the piston but None on the head?
floodgateus wrote:Also is it normal to have carbon build up on the piston but None on the head?
On this 2 stroke motor, the exhaust port is on the side of the cylinder, so yes, you would expect carbon build up around the corresponding area on the piston. I've also seen the top of the piston have carbon, but not the head. I suspect this is because the metal on the head is much harder and smoother than the metal on the top of the piston.
you are right Charlotte- the burn marks match to the exhaust port, I will buy new rings and gaskets and cross my fingers..with ga$$ going up up up, I plan to use this scooter for local transport!
The exhaust port is immaculate-that is what is so puzzling about this- everything seems to be in good shape but no gas is getting from the carb to the s/plug
