Electric Impact gun for pulley bolt?
elnene2k
Post by elnene2k »
I'm trying to figure out if an electric impact gun would be enough to unscrew both pulley bolts for my Aero? Any suggestions out there...I already found out a couple tricks from searching but just checking to see if people have new suggestions...
1983 Honda Aero 50 (Restoration Project)
2002 Honda Metropolitan (Fiance's Beast)
mopedman
Post by mopedman »
well we got mine off today by sticking rope in the hole for the spark plug then you use a ratchet and a socket, what happens is the rope makes the piston lock up cause it cant go up all the way it work really good
2005 Yamaha Zuma
1985 Honda Spree
1978 Honda Express
CharlotteSpreeRider
Post by CharlotteSpreeRider »
The impact wrench should work. I don't have one, so I use the methods you are aluding to.
-aseigler
kolohe
Post by kolohe »
I use an electric impact and it works fine.
gobucks
Post by gobucks »
the electric gun works well i do it all the time, also an air gun works
elnene2k
Post by elnene2k »
OK Cool...I'm just going to go buy this one at Sears...it got great reviews and the maximum torque is 900 in lbs which seems alot for n impact gun! Not bad price either..
