Elite engine dies out at WOT
gobucks
Post by gobucks »
my engine dies out at wot, it's really annoying when your bike can't show its full potential, does anybody know what this could be?
Post by Kenny_McCormic »
Its either lean or rich. if you hold your hand over the air intake holes and it runs better its lean, if it runs without an air filter/cover its rich.
gobucks
Post by gobucks »
i just covered the air intake hole in the air cleaner housing and it runs great!, so, what do i have to do to fix the lean fuel mixture ( i have a stock 68 jet), and the carb has been cleaned about 5 times.
mopedman
Post by mopedman »
check for air leaks...... is your air filter oiled
2005 Yamaha Zuma
1985 Honda Spree
1978 Honda Express
Do you have an air filter?
gobucks
Post by gobucks »
i have an air filter and i just oiled it, where do you think a probable place for an air leak would be at?
mopedman
Post by mopedman »
the tube going from the air box to the carb. make sure it is on good
2005 Yamaha Zuma
1985 Honda Spree
1978 Honda Express
gobucks
Post by gobucks »
hi, just checked hose to carb and its great, i unplugged the auto choke wire and the bike runs great, is there a permanent fix for this?
Plug the choke back in and fix it the correct way, use an unlit propane torch to check for leaks.
CypressRon
Post by CypressRon »
How do you check for air leaks with an unlit propane torch?
mopedman
Post by mopedman »
u blow it on the the air box, intake, air hose.... any were you think it is leaking.... if the engine starts to rev up when you go over a spot that is were it is leaking
2005 Yamaha Zuma
1985 Honda Spree
1978 Honda Express
gobucks
Post by gobucks »
i can't find a leak with the torch, the engine doesn't even rev up when i put the torch straight into the air filter box. Is there anything else that i can do?
