gutting the exhaust?
snowdaze00
Post by snowdaze00 »
I know its not the best thing to do but i think our exhaust is pretty much trashed on the inside anyway. Not that long ago the exhaust was plugged and we did the fire pit deal and it ran great again. Now the exhaust is blocked again (less than two tanks of gas). I think there is so much junk in there rattling around it finnally got blocked.
We removed the exhaust and it ran great so we know it is plugged or blocked.
I want to cut it open and remove anything in there that is loose.
Any one have a suggestion on how to open up the exhaust? I was thinking of cutting int it on the back side so all the bolt locations do not move, then weld it back into place.
What do you think???
Post by Kenny_McCormic »
Can you weld it back together?
adark248
Post by adark248 »
Kenny_McCormic wrote:Can you weld it back together?
duct tape?
1984 Honda Aero 50
1986 Honda Spree
snowdaze00
I dont have a welder but friends do.
evilone
Post by evilone »
If you do cut it open take pics and post them, I want to do the same, if I do it first I will post pics.
snowdaze00
OK - no problem
Its not gonna run well if you gut it. Try dipping it in lye, might dissolve junk the fire dislodged.
chevyguyjay
Post by chevyguyjay »
i gutted my SE50 muffler. and cut it opened length wise and removed all the small pipes with larger ones.( the same size as the inlet) i can tell u it made a big difference in the way my scooter performs. my opinon, drilling out baffles is a waste, and u loose some back pressure. i could be wrong on the spree engines though. :wink:
~2004 Geely Fashion~
jstone
Post by jstone »
I know my exhaust is clogged up i just haven't got around to fixing it yet. The guy who had it before me tapped the pipe right after it expands a little bit, but before the actual muffler and put a screw in it. With the screw out it has terrible take off, but a higher top speed. With it in it has good take off and a decent top speed. I just thought that was interesting...
snowdaze00
well its gutted, all that came out was a round disk part with some holes in it. There is still a spark arester looking part that is where the large muffler part begins and I still have the small outlet pipe in place.
I took pics and will post later. We have not reinstalled the pipe yet to test the outcome
more to come after weh put it back together.
snowdaze00
so far the scooter is running great. top end on the speedo is about 29 for my 110 pound 13 year old.
Pics comming soon.
jstone
Post by jstone »
What about the bottom end? Thats what i figure it would hurt the most.
snowdaze00
bottom end is the same if not better. keep in mind the parts I took out of the pipe have been rattling around in there for a while, so i really dont think we changed anything......... might have a bit deeper sound but seem to run well.
snowdaze00
I never did post my pics. I do have them. Can someone post them for me, I will send them to you.
justinnielsen01
Post by justinnielsen01 »
i will post them send them to justinnielsen01@live.com and you can buy an exhaust from nosiey guy he makes them for 100 bucks
