Best place to get tires?
I have those exact tires on my Spree. The seller put new ones on it so luckily I don't need tires for a while yet. And yes, the price seems pretty good. $46 shipped for two tires to me. Or buy $100 worth of stuff and get free shipping.jstone wrote:I just ordered a set of these, i haven't got them yet but i thought the price was decent.
http://www.cbxmanmotorcycles.com/Kenda- ... 50-10.aspx
1985 Honda Gyro S (project bike, work in progress!)
1984 Honda Spree - Bought May 30, 2008 with 810.8 miles on it. (Sold with ~1600mi)
Others owned/rode/sold: '86 Helix trike, '07 Vino 125, '88 Elite 250
Dac wrote:Friends+your moped=BAD IDEA.
I get tires from this place:
http://www.americanmototire.com/catalog ... ?cPath=362
they have the best selection and good prices
- CharlotteSpreeRider
I'm not super impressed with their selection for 2.50x10 tires, but the one that they do have, the Cheng Shin C800 is under $10, which is the best price I've seen.booism wrote:I get tires from this place:
-aseigler
Sweet mother of the FSM, no! I would never do that. Most places would charge more than the tires cost to put them on your rims since you didn't buy the tires from them. I use two flat head screwdrivers to get the tire off, just like a bicycle. To get the tire on, I slowly and carefully press the tire on by hand. You have to go slow and push like * on the bead with your thumbs. It takes a while, usually takes me 20 minutes per tire, but I can get the tires on eventually without using any tools. It's not easy, but I don't end up damaging tires or tubes that way, ever.adark248 wrote:hey CSR how do you install your tires? Do you have to take them somewhere that has one of those stretching machines?
-aseigler
soapy water works great.CharlotteSpreeRider wrote:Sweet mother of the FSM, no! I would never do that. Most places would charge more than the tires cost to put them on your rims since you didn't buy the tires from them. I use two flat head screwdrivers to get the tire off, just like a bicycle. To get the tire on, I slowly and carefully press the tire on by hand. You have to go slow and push like * on the bead with your thumbs. It takes a while, usually takes me 20 minutes per tire, but I can get the tires on eventually without using any tools. It's not easy, but I don't end up damaging tires or tubes that way, ever.adark248 wrote:hey CSR how do you install your tires? Do you have to take them somewhere that has one of those stretching machines?
-aseigler
Noticed my rear tire looked a little low today, so I pulled out the pump and brought it back up to correct PSI. While I was working on my bogging issue it started hissing. Apparently the tube popped because it let all the air out and won't hold air anymore.
Looks like I'm in for that new set of tires for sure now.
1984 Honda Aero 50
1986 Honda Spree
1986 Honda Spree
Harbor Freight sells two tire changes:
Mini Tire Changer - $36.99
http://www.harborfreight.com/cpi/ctaf/d ... mber=34552
Portable Tire Changer - $39.99
http://www.harborfreight.com/cpi/ctaf/d ... mber=34542
Wal-Mart will mount them for slightly cheap if you don't wanna bother doing it yourself:
"Tire Mount (Lawn & garden, boat trailer, golf cart, ATV) $5.00 per tire"
Nah, dont need no fancy tools, just run it over with a truck, bead pops right off. Of course with a bicycle tire you find on a spree that isnt necessary. Little soapy water and they pop right on/off.
My local Tire Express does it for free.Cubey wrote:Harbor Freight sells two tire changes:
Most places will mount for free if you buy the tires from them. Its the balancing and valve stems that you pay for. This allows them to advertise "Free Mounting!" and no one is going to get car or light truck tires mounted without having them balanced. With scooter tires you wouldn't need the balancing or valve stem so you can take advantage of their offer.
